Play-Mor
Well, I'll chime in with a brand that hasn't been mentioned here, good or bad. Play-Mor. Apart from seeing them on the highways, I first ran across them in the middle 1970s when I was doing mobile home work in the L. A. area. Play-Mor trailers were often used as the "retreat and make-up" trailers for the second-line actors at studio back lots and on location. The trailers weren't necessarily fancy inside or out, but they held up well to years of hard use.
A number of years later, I ran across them again, this time when an employer bought a batch of five of them in about 27 foot lengths for field use. Those trailers got rough use in deserts and mountains, on paved and gravel roads, and stood up well. Really well. (The Play-Mor that was assigned to me got used three years in a row for a college field class library in the desert. ) One of them was caught in a freak windstorm headed down Cajon Pass into San Bernardino, and it blew over on its right side. (I wasn't there for that incident. ) The hitch popped off the ball, but the chains stayed attached. With some assistance, the crew got the trailer righted and re-hitched, and it made the rest of the trip to Riverside and then El Centro without incident. It was in use for some weeks before it got repaired. The entry door worked, not well, but it worked.
I moved on to Arizona, where I bought a Yukon by Wilderness & Fleetwood of my own. It was a learning experience. I will leave that subject there. PM me for the gory details.
Soon after we bought the 1996 Dodge, we bought a new 1996 Play-Mor 2350 Aero travel trailer, which has been 99. 99% trouble free. Play-Mor is a small outfit, and the last time I looked, they had only one factory, in Missouri. The units aren't necessarily fancy inside, though they can be ordered that way. For example, ours has sheet vinyl flooring throughout, except in the bedroom area. (I'm a geologist and we have two immense dogs, so vinyl flooring is a
good thing. ) Where it was possible to do so, Play-Mor installed appliances and equipment that were one or two grades above the bare minimum that other manufacturers used. This has showed over the years. Only now am I having to replace the furnace motor. Cabinet latch problems showed up, in 2008.
As I mentioned, I used to do mobile home work. I did that to pay for college. It doesn't matter what brand of fifth wheel, travel trailer or mobile home you buy, all of them are going to use putty tape as a sealer when they build the thing. There's nothing wrong with that if it's done well. There are two kinds of putty tape. The cheapest kind is basically oil-impregnated clay. The other kind is butyl-rubber based, but slightly gooey. Oil-based tape is usually gray or very light tan in color. Oil based putty tape holds up long enough to get installed, and will seal for a few years. Then the oil based stuff will shrink and leaks will begin. These leaks are usually in places you can't see, until the framing rots enough for bulging to start. Butyl based putty tape doesn't dry out (even here in Arizona). Butyl-based putty tape is usually brilliant white, but it can be made in other colors to order. It won't shrink, and if it was installed right, butyl tape won't leak unless it is physically damaged.
Our Play-Mor was assembled with butyl tape. So were the Play-Mor trailers I dealt with in the 1970s and 1980s. My Yukon used oil-based putty tape. (I should have known better!) Butyl based putty tape costs about twice as much. So it will add $50 to $200 to the cost of a trailer, depending on the size and number of windows. You can't predict whether or not a trailer will use butyl based tape by its price. Expensive brands may be fancy on the surface, but inferior underneath where it can't be seen. The Play-Mor line, when I bought mine, was on the low end of medium price.
If you are going to buy a used used RV, there's a trick you can try to see if there have been leaks into the framing. This will only work where you can access some of the hex head, phillips head or No. 2 square drive screws used to hold on the siding or clearance lights, or some other part that goes into the framing. Take out several screws, one at a time, and inspect them. If they are rusted, water has gotten to them. If they are badly rusted, water has gotten to them and the wood has been soaked for long periods. If the rusted screws won't retighten, the wood is rotten.
Disclaimer: I don't get a commission from Play-Mor.
