Most of the better brands now build them with aluminum frames now including my HitchHiker but here is something a prospective buyer should consider:
First, all trailers use a steel frame under the body. The only parts that use aluminum or wood framing are the walls and ceilings.
Until 2010, NuWa built their top of the line Champagne model which is a very high quality fifthwheel using hardwood framing but had shifted the middle level Discover America (my model) and the lower priced HitchHiker II now HitchHiker LS to use aluminum framing.
I have had several lengthy discussions with one of the older, experienced NuWa regional sales managers about the subject. He becomes visibly angry and very animated when he gets into the discussion. He said that hardwood framing is actually much better and much more durable than aluminum for several reasons and is actually more expensive to build.
He says that wood framing will flex and give a little as the long unsuspended middle section of a large trailer between the axles and the kingpin in the upper section of a fifthwheel or tongue coupler of a conventional trailer sags and flexes while traveling. Wood framing is less likely to split and break while the aluminum frames often break at joints because the welded joints fracture under stress. The sales manager claims that weight difference is actually very small. He said NuWa built two identical trailers several years ago then weighed them. One used wood framing and the other used aluminum frame members. The weight difference was very small according to him.
He says the reason NuWa shifted over to aluminum was because the Elkhart brands began advertising aluminum frames as superior about 10 or 15 years ago and persuaded the buying public aluminum is better. He said they had to deal with the question for years and found it difficult to convince prospective buyers that hardwood framing was actually better. Eventually they surrendered and changed over to aluminum.
He claimed that the only real advantage of aluminum over wood was when roof seals or joints or windows/doors leaked and allowed water intrusion over a long period of time. Wood framing will eventually rot but it is actually the floors that fail, not the wood framing. All RVs use some sort of wood product flooring.
When the sales manager and I speak of wood framing neither of us mean the thin, flimsy, low grade sticks attached by an occasional staple in the cheapo brands.
