Beware Packbrake AIR BAGS
Pacbrake Air Tank Location
Front end alignment
Eric, are you saying if I hook a light up to that wire it will dim with the other instrument lights?
Uhmmm, I think so. All of mine dim with the instrument lights. I'm not sure if this is the wire I hooked to, but I think it is. :confused: :)
--Eric
I got it figured out. The side panel of the instrument panel comes off giving easy access to the plug behind the light and dimmer switch. I tested all the wires for about a half an hour and couldn't find any power. I got the bright idea to check the test light. guess what, bulb blown. I was pi$$ed. Got another test light, found the hot wire, and hooked up the light to the pressure gauge. I'm a happy man.
Tim
The sharp point on my test light would have been imbedded somewhere in the shop wall right about then. :-laf
Did you take notice of which position the correct wire went into?
No I didn't. There were 5 or 6 wires going into that plug, 3 were orange with a brown strip. It was one of those. If you need to know I can check and report back.
