Anybody that has had these size E-Rated tires, on a 3rd Gen truck, have you noticed a backend "seasway" or "waddle" - it's scary if you have to jerk the wheel to avoid hitting something in the road, then jerk it back to recover. I noticed it right away after the tires were installed today. I have new Bilstein 5100 shocks on the truck.
I had also noticed it a little bit with the TOYO Open Country AT's 285/70/17, but now, notice it a great deal more! I know the sidewall is a bit larger, but with an E-rated tire, I did not expect it. I had a load on today (3 yards of mulch) and that didn't calm it down either (yes tires were properly inflated for the load).
By my calculations (if I did this right): multiply width by . 70 or . 65 (70% or 65% of width = sidewall height).
Stock 265/70/17 has a sidewall height of 7. 23" (185. 5mm x . 039 = 7. 23)
Toyos 285/70/17 has a sidewall height of 7. 78" (199. 5mm x . 039 = 7. 78)
BFG's 305/65/17 has a sidewall height of 7. 71" (198. 25mm x . 039 = 7. 73)
These tires sidewalls are only 13mm (~1cm) higher than stock - so why the sway? On my other truck, that still has stock tires, the side wall looks much smaller when parked side by side (by 2 inches), compared to the new BFG's, than my calculations above - so I might be wrong on how to calculate sidewall height.
I guess that anytime you go bigger than stock size, your just going to have to install a rear stabilizer bar.
Any good suggestions on a rear stabilizer bar? Will that even help?
P. S. I am suprised that no one else has metioned this, as I simply can't be the only one who noticed this after going to two different size larger tires.
