CBoerm
There have been some negative reports about K&N on this web page. There are also some very satisfied users. I an oen of the latter.
I have the FIPK II (#57-1525). I like the hard plastic, smooth sided intake hose from the filter to the turbo. Gives smoother airflow. I also like the heat shield. Many report debris and lots of oil in the hose and intake of their turbo. I suspect over oiling or under cleaning. . Mine has been on for 20,000 miles and intake is spotless. The quality of my K&N is as good or better than any others I have seen.
K&N's customer service is excellent-I broke the securing nut off the small end of the filter (my fault) and could not figure out how to replace it. Called K&N, found it could not be replaced due to sealed filter - got now filter at no charge.
I'm over 400 hp and get all the air I need. I suspect those having problems are higher HP and working their trucks a lot harder than am I.
Real question, in my mind, is oiled vs non oiled filter-which is best. Have read nothing definitive either way; think the vote is still out on that one. I see no downside to oiled and can recommend the K&N.
