Did anyone who uses the BHAF in their truck have any problems with it being crushed by the hood. I am afraid mine isn't fitting right. Also, did you reuse the clamps that were on the intake hose, or did you put new clamps on? I could barely get the intake over the filter lip. I am afraid it will pop off, or I will crack the filter base. I used a piece of 3/4 plywood as a base over the studs because I didn't want to make it irreversible. I just hope I'm not hurting the filter by squeezing it between the hood and my base. The base doesn't stick up any higher than the original studs.
Thanks,
Travis
Thanks,
Travis
