Engine/Transmission (1998.5 - 2002) Bhaf?
2nd Gen Non-Engine/Transmission Front end turning weird
Engine/Transmission (1998.5 - 2002) Is it a calif. truck or not?
Where can I find any information on BHAF?
I have read that NAPA has them. Does BHAF stand for Big Honkin Air Filter? Any information necessary for ordering would be great.
Thanks!
Alan
BHAF does stand for big honkin air filter
BHAF Part numbers
Fleetgaurd# AH19037
Wix # 42790
Napa # 2790
Carquest # 87790
Donaldson # B15006
Baldwin # PA2820
John Deere# PMAH19037
You should be able to get one for $30 to $40 :)
Jared
BHAF
Thanks Guys!
Did you have to make an adapter to fit the turbo hose and a plate to seal off the back of the filter?
Alan
No plate required. It is sealed on one end, and has a neck on the other that will plug into your existing hose. Some have chosen to use a piece of PVC pipe to connect the BHAF and the hose, but I just hooked mine right up. I have the fleetguard version.
Larry
Does the BHAF meet the Cummins requirements for air filtration? If it does it just seems quite a bit cheeper than an AFE or such. How often do you change?
Been running mine with out any support in the neck of the filter since Moparguy found them... no problems and silicon levels are less than with stock or a KNRE0880. My Dad also has one, no problems and good oil analysis. I did cover both or ours with outterwears covers, just to make them splash proof. .
