I have been looking for a big chrome tip for my 5" exhaust, but have been unsuccessfull at finding a good solution. Can anyone recommend a place to find a big tip?
My current tip, which I like very much, is a Summit PN: SUM-691119
This tip is a 4" inlet, to 5", with a slant sut, rolled tip. The slant cut is only about 10 degrees, not a 45 degree miter tip. What I'd like to find it the same thing, but 5" inlet and 6" outlet, slant cut.
I have thought of hacking the 4" off of my 5" tip, but I want to exhaust my other options before I hack the tip.
By the way, to those of you with stock exhaust, this Summit tip is perfect to go over the flared end of your stock tailpipe. It fit so tight I had to heat the tip with a propane torch to slide it up on the pipe. I didn't even need a clamp after it cooled, but put a band clamp on anyway.
Any pointers in the right direction will be appreciated.
Thanks,
Chris
Thanks,
Chris
