Competition BIG MONEY PAYOUT PULL IN MISSOURI JULY 21st
Competition cr cyl head mods, whats best ?
1st Place-$2,000
2nd Place-$1,250
3rd Place-$900
4th Place-$650
5th Place-$500
Plus Trophies
Go to PlatteCountyFair.com for rules or call me at 816-365-1725 and i will give you a brief run down or fax them to you. Lots of money here would love to have alot of trucks..... this class will be close to the DHRA street class. If we can get enough trucks that want a run what you brung class we will also have that with 100% payback.
Thanks,
Jared Hill
Why not just post the rules on this thread so everyone can see them.
It seems like a lot of money for a "street" class? But that is great to have an awesome payout.
2006 Platte County Fair Street Diesel Pull Rules
General Rules:
1) The Street Diesel (SD) class is designed for streetable pickup trucks (full-bodied diesel pickup trucks).
Valid DOT registration and license plates are mandatory. The vehicle must be four-wheel drive. Tow vehicles are prohibited.
2) Gross Vehicle Weight 8500 lbs. Weight is with driver. A weight Ballast is permitted. Hanging weights may not extend more than 60 inches from the centerline of the front axle.
3) Trucks:
a) The vehicle must retain the original factory wheelbase and track width.
b) The OEM chassis is mandatory. The engine must be in the OEM location for the body used. The vehicle must retain the full OEM chassis. Wheel tubs, back-half conversions, tube chassis, etc. , are prohibited.
c) The body must be the OEM truck body, including the full bed floor, complete OEM floor pan and complete OEM firewall is mandatory. The body must retain full sheet metal. Metal after-market hoods are permitted. Fiberglass is prohibited.
d) The complete headlight and taillight assemblies (all) are mandatory and must be operative. Complete OEM windshield and windows are mandatory. Windows must be operative per factory specifications; that is, they must open and close via OEM electrical or mechanical means.
e) A complete interior, including dashboard, door panels, headliner, etc. , is mandatory. Two matching front seats are mandatory. Aftermarket seats are permitted; they must be fully upholstered. All factory controls (lights, signals, horn, windows, wipers, etc. ) must be retained and be operative.
f) Radiators must be in the stock location and be of at least stock size.
g) The batteries must be securely mounted. They may not be located in the driver compartment.
h) The vehicle must retain the full, original OEM steering gear.
i) Four-wheel hydraulic brakes are mandatory.
4) The engine block, transmission and transfer case must have been available as a factory option on one-ton or smaller pickup trucks. Non-OEM transfer cases are prohibited.
5) The tires must be DOT street tires. Cut tires are prohibited
6) Suspension:
Front; the upper mounting point for strut assemblies must be in the factory location. Adjustable caster/camber pillow ball mounts are permitted. The lower control arm may be strengthened provided factory-mounting points to chassis are maintained. The lower mounting point for the strut assembly may be modified for improved caster or camber. Strut tower braces, lower tie bars, sway bars, and limit straps are permitted. Traction bars and devices are permitted.
Rear; an OEM-style suspension is mandatory. Traction bars and devices are permitted; they must be bolt-on only; welds are permitted for attachment to frame or axle housing. Control arms may be strengthened or replaced, provided all original mounting points are retained. Strut tower braces, lower tie bars, sway bars, limit straps, and camber kits are permitted. The rear suspension must maintain a minimum shock travel of one inch. All rear suspensions must use at least one working shock absorber per wheel.
Rear End; Non-OEM rear-end housings are prohibited. The rear end must have been an option on a one-ton or smaller pick up. Rear axle bolts must be covered by a cap or shield.
7) FUEL:
a) The fuel must be pump #1/#2 diesel only. Soy/Bio-diesel fuel is permitted.
b) Off-road diesel fuel is prohibited
c) The fuel injection pump is limited to a stock-appearing, OEM engine make-specific pump only. Pumps from different years in the same engine model may be interchanged.
d) The OEM fuel tank is mandatory and must be used. Racing fuel cells are prohibited and must be removed.
e) Nitrous oxide is prohibited. No other oxygen extenders are allowed. All system components must be removed.
f) Propane is prohibited. All system components must be removed from the truck.
g) A fire extinguisher system is permitted. It must be securely mounted.
8) Turbochargers from different years in the same make may be interchanged. No larger than 3 inch inlet.
9) Water injection is prohibited. All system components must be removed from the truck
10) All vehicles must be equipped to direct exhaust upward or downward. The exhaust must exit rearward of the driver's compartment. Stacks exiting through the hood or fender well are prohibited. Two 3/8 inch diameter bolts must be placed through the exhaust pipe in a cross pattern within one inch of each other as close to the turbo as is practical.
11) The hooking point must be the rear-most point on the vehicle and must be rearward of the stock location of the tailgate. The hitch must be horizontal to the ground and stationary in all directions. Bumpers may be notched or removed. The hitch's height from the ground may not exceed 26 inches. The hooking point must have a minimum 3” inside diameter opening for the sled hook. The hooking point will be measured to the center of the clevis loop.
12) Measuring: Will be done electronically by the Sled.
13) Protest will require a $100 deposit up front. If the protest stands, the $100 will be returned. If not, the $100 is forfeited.
14) The final decision rests with the Technical Department
Any Questions please contact; Jared Hill (816) 365-1725 or -- email address removed --
Myself,Tony Sinclair of St. Joe Diesel and a few other diesel guys from this area. The outlaws start at 7 and they say they will have a 2 and half hour show. Diesel trucks need to be there no later than 9 p. m unless you call my cell phone and make other arrangements with me. If your going to be late or need other information please call me at 816-365-1725 anytime monday-sunday
Thanks,
Jared Hill
There are 2 nights of diesel truck pulling coming up on July 28 and July 29 in Owensville, Mo
July 28
Pulls start at 7:00pm at the Gasconade county Fair grounds
July 29
Pulls start at 7:00pm at the Gasconade county Fair grounds - This night is a DHRA pull.
No twins in the big money class... ... but we are having an open class with a 50 dollar entry fee paying back 100% to the top 3 places. Run what you brung and hope you brung enough. If you have 20 trucks at 50 a truck split 3 ways thats 500 for first 300 for second and 200 for third. The two changes to the stock class rules are hanging from weights are allowed along with stacks through the hood. If anyone needs anymore info please call me at 816-365-1725
Thanks,
Jared Hill
Did I see Big Yellow Iron post. I must have been dreaming. I didn't even know Adam was still alive, let alone still driving a diesel. J/K ya Yellow good to hear from ya.
I always roll my eyes at this rule. Drive you truck a long distance to throw a driveshaft/bust diff, and then try and get it home. All you end up with is a parking lot on the edge of town of tow vehicles and trailers, with the puller driven the last 2 miles to the pull. :-laf
All in all the rules look very good. Just gotta laugh at the no tow vehicle rule.
Michael
jwilliams3 said:
Yeah tow vehicle means no "mules" or "gators"
OK, I'll buy that. I've been to pulls before where the "street" class trucks had to be driven to the pull, ie no tow vehicles hauling them in. I pulled in one place and they had this rule. I had came 2 hrs, and there ain't no way I was driving my 1975 dodge truck, no a/c, 4 spd, 410 gears, gas hog 440, to risk hooking it to the sled and hope to drive home. They changed the rule to, "If you lived within 20 miles, you had to drive your truck in, anybody else could haul them in. "
Michael
Michael
Note that the rule doesn't say 'no trailers', only that the puller has to be driven to the event. The obvious solution to this quandary is to use the pulling truck to tow the backup truck to the pull (like Tomac used to do). And maybe leave the backup truck on the trailer until after the puller has been teched in (eliminates accusations of switching trucks). Offers clear proof that the truck is very streetable.
N
