I'm with Tim,my 3500s return hose started leaking only while running,I was on E from a full tank in 200 miles,middle of nowhere,had to buy fuel from a farm house's diesel tank. You will find a drip when you first shut down though. You can try adjusting the valves.
You didn't say whether you also had a power loss,which will happen with a faulty waste gate.
The winter fuel will usually only drop your mileage about 2 mpg,but it all depends where you buy it. Winter fuel is climatized for the area where it is sold,farther north or higher elevation fuel can contain more #1 diesel which can bring your mpgs down more. You don't have a lot of miles on the truck so I am assuming you don't fill up much,try a differeent brand next time and see if it helps. You already checked what could be the most likely problems,there aren't many more unless you also have power loss.
95' 25004X4,AT,Driftwood,Banks Stinger,Warn fender flairs and running boards(work truck)
95 3500,5 speed 3:54,BD E-brake,Driftwood,Banks&Psycotty,34,000 GCVW apple and tractor hauler(works harder truck)
