Last Sunday I drove about 70 miles and when I got out of the truck to get something to eat I noticed oil pouring out of the passenger side of the engine compartment. I shut off the engine and opened the hood. Oil was pouring out of the coolant reservoir overflow. Now, I noticed nothing while driving, no temp differences, no pressure differences. There was not any water/antifreeze in the oil. All of the oil was pushed out of the engine along with the water/antifreeze. The radiator is full of oil. I put oil in the engine and drove it on then off of the trailer. It starts fine, runs good, just pushes all of the oil out.
Since then the engine has been tore down. The head is fine, the gasket looked fine, except for a tear between the oil hole and the #4 cylinder on the top side of the gasket, which could have happened while I pulled that nice light head off.
I also have had the oil cooler checked and it is fine too.
Is there anything else I should check before putting ole' Stack'd back together, because at this point I can only blame the tear in the rubber part of the gasket for the oil leak and I hate to get it back together and the same thing happen. Thanks in advance.
1998 CUMMINS Dodge Ram
that has absolutely NO modifications!
