lmills said:And some more.....
Sorry im new to looking at engine parts, so without holes or melted metal im a little lost in what im looking at. Could someone point out what im suposed to be seeing as bad?
Thanks
lmills said:Ok, the owner came down this evening and looked over the damage. Apparently he said the issue began about a month ago while he was towing his cattle trailer across the state and hasn't driven the truck much since
The thermocouple was mounted directly in the path of the cylinder that burned up and he says the exhaust temps climbed to around 1550 degrees and he turned the water injection on to cool it down. After the water came on temps dropped to around 1300 degrees, but shortly afterward the truck started to run rough and smoke excessively. At that point in the game he had stock injectors and the BD Super B turbo on the truck.
When he got it home he sent the injectors out to be checked thinking that maybe one of them was going south. He got the new injectors in and noticed the rough idle was still there and that the truck was burning oil. He then checked the turbo and found that it was blowing oil into the innercooler.
So, he only had the stock charger on the truck long enough to get it to my place. That explains some of the things that I found on the truck. We will be yanking the engine the first of the week and we will go from there as to whether or not he will be going with a shortblock or rebuilding the existing one.
MAshley said:Sorry im new to looking at engine parts, so without holes or melted metal im a little lost in what im looking at. Could someone point out what im suposed to be seeing as bad?
Thanks
CStraface said:Can you explain the differences between "a shortblock and the existing one"????
Thanks
lmills said:The thermocouple was mounted directly in the path of the cylinder that burned up and he says the exhaust temps climbed to around 1550 degrees and he turned the water injection on to cool it down.
MTomac said:the motor isn't even broke in yet
JasonCzerak said:I can see how it makes things faster. As far as cooling down I'm confused.
Correct me if I'm outa the ball part here.
Water isn't compressible. When it's in the cylinder it takes up space creating more compression correct? Which would create more heat (melting things) while making more power, higher compression. If you have way to much water you can bend rods.
At what point in the 4 cycles does the water turn into a gas and work with or against the power cycle?
Does water act like an inner cooler or nitrous to cool the intake charge to cool things off?
