Big Question All You Hot Rodders
What oil do you use?
New Truck, anything to do to it?
I currently have 07. 5 Cab Chaise 4x4 auto reg cab w/flat bed 4:88 rear.
This is not my first 95, std. 98,std 06 std. all of them ran like a scaled dog and was abel to upgrade Cold air, chip, cams, exhaust and so on w/o a problem.
every thing I have tried w/the 6. 7 has been a disaster always throwing codes.
No one to my knowledge has come up with solution to the C/C vs std dually.
any ideas:confused:
Wait for Marco to work it out. Word is that as soon as Chrysler stops changing things that he's ready to come out with a solution. If he can't do it it probably can't be done and done right... .
any ideas:confused:
hang in there . these programs will be figured out as time goes by and the mods will work . there has been so many reflashes that the mod people have probably had a tough time keeping up . as things settle down i thik there will be plenty of mods that will work fine .
Thanks for the reply I kind of figured that there were problems. Do want to remove the cat and dft for off road use only of course.
Something you might want to consider or understand, that in CA the B. A. R. is making all off road vehicles, trucks, graders, loaders, everything with a diesel has to be retrograded to Low NOX and Particle Collection or it has to be removed from CA... . They are now re-powering the fleets.....
In the heavy fleets, again, off road stuff they expect this new B. A. R. law to move across the US in the form of an EPA law...
The reason is these vehicles are now the largest group of vehicles that send NOX and Soot into the air in CA.....
And with the 2007 changes most states who do not have a diesel test program or a very simple one... . (snap throttle and look for smoke) are being forced into a higher level of testing...
Here we had the snap test... the equipment is now going in for data testing and inspections... and dyno testing is to follow if the info in the news papers are correct... . I'd never want to be caught with the equipment off the truck... .
