Mike Ellis
We are having heavy rain in the DFW area today, so I got into my camper (mounted on truck) to take advantage of it by checking for leaks. I searched high and low, all the roof penetrations were tight - no leaks anywhere EXCEPT at the bottom of my bathroom window. This concerns me greatly because even though the Bigfoot is a fiberglass shell, it does have the wood "luaun" sheets on the fiberglass / foam sandwich and if this rots it would be susceptible to delamination or bubbling.
This is a fixed window (no sliding opening), it is a radius edged one-piece looking window. On the inside, there was no moisture in the frame or channel, but a tiny amount was seeping out from under the frame on the bottom left side where it meets the wall.
I looked the outside over closely, there is a good silicon bead all the way around the frame. However, the glass has a sort of rubber strip that runs around it, with the joint in the middle of the bottom. There are also two small plastic inserts or latches (storm windows??) on the bottom, these were out a bit so I poked 'em back flush.
QUESTION: How do I figure out where the water is penetrating? Anybody familiar with these sort of windows and what to look for?
(I just had the roof resealed at Camping Country RV in Colorado Springs back in July, if it is leaking from a roof point I am going to be
