Bill,
Go see the parts dept. at the Dodge dealer. Tell him you need a new speedometer pinion for your taller tires. Write down the exact numbers for the tire. Example, 285/75R16 ect.
Take out the OE one, and put the new one in. Simple job. The adapter is on the tranfer case. Just remove the bolt on the adapter clamp, and replace the OE pinion with the new one.
If you need more info I can help.
Bill R
94 2500 SLT 4x4 5 Speed, 3. 54 LS, JRE 4" exhaust, Autometer Pyro, Boost & Water temp gauges, Bosch 215 HP injectors, Timing @ 14. 7 º, JRE Stage III #4 plate 270/675, AFC spring kit, Scotty Air, Bully Dog Propane Injection, Roadmaster Active Suspension, Optima Red Tops, Geno`s Exhaust Blanket,Espar Heater (won it!), Synthetic lubes throughout.
[This message has been edited by HEMI®Dart (edited 11-26-2000). ]
