You can go to a 5 mm valve stem, it flows more , but unless you bore the block the valves are close now. This is the primary reason to bore a block. Ray will send you valves, but there in no secret to them, all the above mention get them from valves makers,Manley , Dell and REV and these sources are available to anyone. Just changing valves will not gain you much, there is an enormous amount of flow to be gained by valve angles, and seat angles, , but unless the head porter has, a flow bench ,and has the knowledge to find these gains they are just grinding metal blind.
