2nd Gen Non-Engine/Transmission Bilstein/Rancho/OEM replacement shock questions.
Engine/Transmission (1998.5 - 2002) 1st fuel filter change!!!
I figure that the owners of RV’s would be knowledgeable about shocks, so I am also posting this in the “Towing, Hauling & RV” forum.
Rancho RS 9000 shocks have a nine-position external (manual) adjustment and an optional “in cab” remote controlled adjusting system. The total package is quite expensive. Then there is the additional mounting of the remote adjusting system air compressor, 12V. wiring, gage panel and the routing of the small control air lines etc. Friends that I have talked to say that with the RS 9000 shocks, if you don’t get the remote adjusting system you are wasting your money. I. e. after the newness wears off, you will get lazy, find an acceptable “mid” adjustment (not to tight for unloaded and not to loose for loaded conditions) position and leave the shocks at that setting. In which case you could have purchased “non-adjustable” shocks for a lot less money and had the same thing.
Rancho RS 5000 shocks are “Gas charged self adjusting” with “ten stage velocity sensitive dampening” “that gives comfortable highway ride and superb off-road performance”
Bilstein uses a “Rising Rate Self-Adjusting Digressive Working Piston” whereby the rate of damping increases as movements become more rapid. They also say that they contain no ball check valves or moving parts other than pistons and are gas charged.
Monroe says, “The Sensa-Trac shock's precision tapered grooves allow the fluid to freely flow around and through the piston. The result is a smooth and comfortable ride. When the piston travels beyond the tapered grooves, fluid is directed totally through the piston, this results in extra vehicle control. ”
My truck is rated at 8,800# GVWR with a 6,000# rear axle, the 5th wheel GVW is about 12,000# including a tongue weight of 2,000-2,300#.
Will any of these systems give the pick-up a better un-loaded ride while still having stiffer damping when loaded in comparison with OEM replacement shocks? For “on” pavement use only, is shock oil foaming really a problem? Are “Gas Charged Shocks” necessary? Which of these are systems are actually better? Etc.
It seems that the more you research a question the more confused a person gets. IE: “Our” brand A is exactly like their brand B except… which means that ours are better. It naturally follows that the brand B dealer will say that being different from brand A means that theirs are better etc. I am asking for input from the real world, not just listening to salesman hype.
It appears to me that the Monroe Sensa-Trac or Rancho RS 5000 system would be better for my use. With small and slow movement of the suspension system the shocks would have minimum dampening effect. When a “large bump” occurs and the suspension system has a long distance of fast travel the shocks then “tighten up” for more dampening control.
The “Rising rate” and other systems seem to get stiffer as the rate of continuous oscillation increases, independent of load or suspension travel distance.
Am I missing something here or am I just confusing myself?
Thanks in advance for your thoughts and input.
The springs on the truck is what gives the unloaded ride the roughness. The shocks only serve to dampen the frequency so that the truck doesn't continue to bounce.
I have the Bilstein's on my 3500 after trying the Monroe Gas magnums (which worked on my 89 Cummins but wore out every 25,000 or so). I have 100,000+ on the Bilstein's and they are jsut now starting to give some of the bounce back into the front end. When new, these totally eliminated the bouncing by controlling the rebound following the compression of the front end.
I plan on replacing them with new Bilsteins when I rebuild the front end with new a-arm bushings and ball joints here shortly. The Bilsteins are suppose to have a lifetime warranty - I'll let the club know if they don't honor it but I believe they will.
yes, oil foaming can be a problem even in on-highway trucks - just think expansion joints and think what that shock is doing at highway speeds. Do they need to be gas charged? No, but it doesn't hurt either.
Rod diameter size and rebound characteristics are important.
I like my 5 position RS9000s fine but I hear the Bilsteins are better - some use Bilstein on the front and RS9000 on the rear for the adjustability. . My fronts stay on 3 and I made a compressor setup for the rears and the airbags. A $15 compressor, three way valve, two gauges, Nycoil tubing and some fittings - it's the only way to go for hooking and unhooking a lot. Yes, better front shocks help a lot - especially in dips, it doesn't bottom out. I think the back end is about the same ride as OEMs when (RS9000) set on 1. Bilstein may be better on washboards - the RS9000s are better than OEM but not great. Craig
I just replaced the shocks on my 01, 3500 with bilsteins and its like a new truck, nice and smooth ride. Its the only shock to go with.
RS 9000
I think the RS9000 shocks are much better than OEM. I have no complaints with the Ranchos except the painted surface rusts quite easily. I adjust the shocks manually to match the load -- it's quick and easy.
I can't compare the Ranchos to any other aftermarket shock since I haven't tried the others.
Ranchos Way to Go!
I had the 5-position Rancho RS9000s on my 00 2500 4X4 and I have the 9-position RS9000Xs on my 02 3500 4X4. Folks who drive empty all of the time might find the "happy middle ground", but I change mine whenever I hitch up my 16K lb 5th wheel w/ 3,200 lb pin weight and my 20' enclosed car hauler.
IMO, you may not need Ranchos if you don't have a large variety driving conditions. My wife's 96 1500 Ram does fine with Gabriel HD gas shocks.
Wiredawg
I'm real happy with the Bilsteins, but have no comparison except to the original shocks that had 90k on them and were shot when I took them off. Changing shocks can be some work in some cases, you might keep an eye on Camping world, they at times have sales on shocks with a cheap install when purchased. I also don't blame you for DIY, I did mine and it wasn't too bad.
Bilstein and Rancho adjustable - Very good
Edelbrock IAS - Don't waste your money, they use the same shock for light duty 1/2 ton and HD 1 ton. Doesn't work.
shocks
I just put Bilsteins on my 2001 3500. I changed OEM's to Rancho 9000 (lasted three mos. ) to Monroe Gas Magnum's(lasted 3 mos. ) now rides great again with the Bilsteins. They have only been on 2 days so we'll see... They are the best so far for the ride though. I have a 3500 lb camper on it permanently that I live in as you can see by my signature...
Hi everybody!
Sorry, I didn’t mean to ignore all the responses to my question! Monday afternoon after I made my post I came down with a case of Montezuma’s Revenge and as a result didn’t get far enough from the “John” to respond to any of the replies. Then of course came Thanksgiving when two of our boys and their family’s were here for 4 days. Again no time to respond.
For my application it looks like Bilsteins for me. Now if Camping World in Draper, UT (or State Trailer, SLC) would have them on sale when we head for AZ after Xmas.
Thanks again for your input.
Richard
I put Monroe Sensa-tracs on my wife's 4x4 Durango that is only driven on the street. They are leaking after less than a year and about 8,000 miles.
The Bilsteins are rough in an unloaded 4x2 single rear wheel. They are great off road and when loaded. If you tow or carry loads in your truck most of the time, they are the best bet. If you are unloaded and not towing most of the time, the adjustable Ranchos are very good. They can be set to a softer initial setting, which is not possible with the Bilsteins.
FYI
After looking at all the interesting replies concerning my post about replacement shocks, I decided on Bilsteins.
In checking prices and availability I found that the ½ (1500), ¾ (2500) and the ¾t. 8800# GVW including the Cummins Diesel powered Dodge Rams all use the same shocks. (Front, B46-1907 and rear, B46-1908) After reading a post about not getting a “one size fits all” brand, I was quite surprised that Bilstein does just that, one supplier even indicated that the 3500 w/o solid front axle also used the same shocks.
BTW, Camping World currently has the Bilsteins on sale for $49. 95 ea. Most other suppliers were asking about $59. 95.
Thanks again for all the replies.
Richard
Originally posted by richardcoxid
FYI
Richard
You might want to do a search on Blistin shocks. I know in the past it has been discussed Blistin does make a heavy duty shock for our application (not a one size fit all) and listed the part numbers for the front and rear.
those #'s are for the 1/2 ton truck. You want these Bilsteins:
Model: Ram (GVW Over 8400 Lbs. )
Year: 94-02
Setting: HD
Front: BE5-2549
Rear: BE5-2550
Year: 94-02
Setting: HD
Front: BE5-2549
Rear: BE5-2550
I concur. These fit my 2500 but the receipt said they were for the 3500, so I assume they fit both. They are for 4wd, the 2wd may be different. Call Offroad Warehouse, (check the links) Tell them you want the TDR discount and what you have. I'm not affiliated, just a satisfied customer. :)
Don't overlook KYB if you are shock shopping. I've gotten excellant performance from KYB Gas-a-Just on my 2wd. Since I purchased my KYBs they introduce a heavier duty version called Mono-Max.
A buddy put KYB G-a-J on his 2wd Ford and they were not enough. That front end really calls for heay shocks to keep that long swing arm suspension from eating the tires.
Bilstein is very good, too.
I will never use a Monroe product again.
Bilstein Owners
I will install my new Bilsteins tomorrow, replacing Gabriel Ryders.
I am hoping to eliminate the expansion joint slap when UNLOADED. The bounce @ 65~70 mph is real nasty. Loaded the Ryders worked fine. Someone quick reassure me I'm not wasting my time/money on the Bilsteins.
Jay
the Bilsteins have not done much for unloaded finesse on freeway expansion joints, I still get a terrible ride at 70. But they sure did tame the front end well, and overall you will not be disappointed. I don't think that any shock alone can make the rear of a full size HD truck ride well while empty.
FYI II
I don’t know why my previous response didn’t show my signature but my truck is a ’98 ½ Dodge, 2WD, Cummins Diesel.
I just called Bilstein (800 537 1085) and they told me that for 2WD application that the 1500, 2500 and 3500 (w/o solid front axle) uses the same shocks F & R.
The web site (www.bilstein.com) shows for 2WD: 2500 and 3500 (w/o solid front axle) Front B46-1907 and Rear B46-1908.
For the 1500 they show: Front B46-1907 and no listing for the rear.
So Bilstein does use a “one size fits all” in some cases. On the phone they said that the dampening was probably a little more than necessary for the 1500 and a little less for the 3500, But just right for the 2500. This was for reducing parts inventory etc. and that most 2WD’s were used as transportation and not for “off roading” (my interpretation of what they said).
FYI II
I wonder if the 4x4 shocks would fit and work in your applicaton??
