Bilstein/Rancho/OEM replacement shock questions
alot of towing topics lost....
Opinion on Weekend Warrior Trailers
I figure that the owners of RV’s would be knowledgeable about shocks, so I am also posting this in the “Towing, Hauling & RV” forum.
Rancho RS 9000 shocks have a nine-position external (manual) adjustment and an optional “in cab” remote controlled adjusting system. The total package is quite expensive. Then there is the additional mounting of the remote adjusting system air compressor, 12V. wiring, gage panel and the routing of the small control air lines etc. Friends that I have talked to say that with the RS 9000 shocks, if you don’t get the remote adjusting system you are wasting your money. I. e. after the newness wears off, you will get lazy, find an acceptable “mid” adjustment (not to tight for unloaded and not to loose for loaded conditions) position and leave the shocks at that setting. In which case you could have purchased “non-adjustable” shocks for a lot less money and had the same thing.
Rancho RS 5000 shocks are “Gas charged self adjusting” with “ten stage velocity sensitive dampening” “that gives comfortable highway ride and superb off-road performance”
Bilstein uses a “Rising Rate Self-Adjusting Digressive Working Piston” whereby the rate of damping increases as movements become more rapid. They also say that they contain no ball check valves or moving parts other than pistons and are gas charged.
Monroe says, “The Sensa-Trac shock's precision tapered grooves allow the fluid to freely flow around and through the piston. The result is a smooth and comfortable ride. When the piston travels beyond the tapered grooves, fluid is directed totally through the piston, this results in extra vehicle control. ”
My truck is rated at 8,800# GVWR with a 6,000# rear axle, the 5th wheel GVW is about 12,000# including a tongue weight of 2,000-2,300#.
Will any of these systems give the pick-up a better un-loaded ride while still having stiffer damping when loaded in comparison with OEM replacement shocks? For “on” pavement use only, is shock oil foaming really a problem? Are “Gas Charged Shocks” necessary? Which of these are systems are actually better? Etc.
It seems that the more you research a question the more confused a person gets. IE: “Our” brand A is exactly like their brand B except… which means that ours are better. It naturally follows that the brand B dealer will say that being different from brand A means that theirs are better etc. I am asking for input from the real world, not just listening to salesman hype.
It appears to me that the Monroe Sensa-Trac or Rancho RS 5000 system would be better for my use. With small and slow movement of the suspension system the shocks would have minimum dampening effect. When a “large bump” occurs and the suspension system has a long distance of fast travel the shocks then “tighten up” for more dampening control.
The “Rising rate” and other systems seem to get stiffer as the rate of continuous oscillation increases, independent of load or suspension travel distance.
Am I missing something here or am I just confusing myself?
Thanks in advance for your thoughts and input.
Get the Bilsteins they are the highest quality shock and they work. If you do a search you will see that everyone that have Bilsteins like them and many that have had both the Rancho's and Bilsteins like the Bilsteins better.
"Am I missing something here or am I just confusing myself? "
Your are reading the hype the sales staff brews up, that can be very confusing and expensive.
I've used all the shocks you listed, IMNSHO -
A monotube shock will out perform others every time.
Gas charging will make the shock do it's job quicker than non charged. This results in a better ride.
Don't buy a "one size fits all" shock because what works great on a light duty 1/2 ton, will work lousy on a heavy duty 3/4 or 1 ton. Edelbrock is a good example of this.
Monroe SensaTracs work well, but are worn out after 20K miles or less.
Bilstein or Rancho adjustable are currently the way to go on our Dodge/Cummins trucks imo.
I bought the 9000's, adjustable on the shock, because I wanted a comfortable ride solo & the right towing valving. On the 4x4, you can reach the adjustment on the rears thru the fender wells. The fronts don't need adjusting.
I had the 5000's, which were stiff solo & just about right for towing.
Hi everybody!
Sorry, I didn’t mean to ignore all the responses to my question! Monday afternoon after I made my post I came down with a case of Montezuma’s Revenge and as a result didn’t get far enough from the “John” to respond to any of the replies. Then of course came Thanksgiving when two of our boys and their family’s were here for 4 days. Again no time to respond.
For my application it looks like Bilsteins for me. Now if Camping World in Draper, UT (or State Trailer, SLC) would have them on sale when we head for AZ after Xmas.
Thanks again for your input.
Richard
I also went with the Bilsteins and love them, empty, with the 5er on, or with the pickup camper on.
But I would skip camping world, I mean Camping world is a great place, but much better prices can be found for Bilsteins. Search the internet. I think mine came from a place called 4X4 warehouse or something, and ran about 1/2 the price of camping world.
Try this link for starters
FYI
After looking at all the interesting replies concerning my post about replacement shocks, I decided on Bilsteins.
In checking prices and availability I found that the ½ (1500), ¾ (2500) and the ¾t. 8800# GVW including the Cummins Diesel powered Dodge Rams all use the same shocks. (Front, B46-1907 and rear, B46-1908) After reading a post about not getting a “one size fits all” brand, I was quite surprised that Bilstein does just that, one supplier even indicated that the 3500 w/o solid front axle also used the same shocks.
BTW, Camping World currently has the Bilsteins on sale for $49. 95 ea. Most other suppliers were asking about $59. 95.
Thanks again for all the replies.
Richard
Originally posted by richardcoxid
FYI
Richard
You are buying the wrong shocks.
Bilstein shocks
BE5-2549 Fronts
BE5-2550 Rears
These are the ones for our trucks. Hope you can change your order before you get them. ORW has them for $60. 99 each
Good luck
FYI II
I don’t know why my previous response didn’t show my signature but my truck is a ’98 ½ Dodge, 2WD, Cummins Diesel.
I just called Bilstein (800 537 1085) and they told me that for 2WD application that the 1500, 2500 and 3500 (w/o solid front axle) uses the same shocks F & R.
The web site (www.bilstein.com) shows for 2WD: 2500 and 3500 (w/o solid front axle) Front B46-1907 and Rear B46-1908.
For the 1500 they show: Front B46-1907 and no listing for the rear.
So Bilstein does use a “one size fits all” in some cases. On the phone they said that the dampening was probably a little more than necessary for the 1500 and a little less for the 3500, but just right for the 2500. This was for reducing parts inventory etc. and that most 2WD’s were used as transportation and not for “off roading” (my interpretation of what they said).
Richard,
Sounds like Bilstein gave you the "Three Little Bears" story :rolleyes: I would go with the Rancho adjustables in your case. That way you can get them just right rather than roll the dice. The reason many of us wave the Bilstein flag so loudly is they got the damping just right for our 4x4 trucks with the BE5-2549 Fronts and BE5-2550 Rears. Again, I have never seen a "one size fits all" shock work well that's not adjustable. jmo...
