Bilsteins
I just put a set of 4 on my '02 yesterday evening and had all the hardware and instructions with them. I guess I was lucky seeing lot's of you didn't receive all the parts. When I first started to read this thread I got worried, but know now I had everything and the install was a fairly good one except for the drivers side front
On the right rear,I had to remove the sway bar link bolt and push the sway bar link down just a bit so the shock bolt would slide out. Then when I put the new shock back on I installed the bottom bolt the other way so I didn't have to push down on the sway bar link. Seems there's plenty of clearance between the sway bar and the lower shock bolt so I'll leave it like this.
Phil
Phil
