Bilstein Shocks For Gen III 2wd Rams Now Shipping (I'm told)
2006 Laramie questions
Altimeter anyone?
My fronts are on the way.
raychem said:
Just passing along the information!!!
Raychem,
Quck question on installation.
Looks like the frontend might have to come up pretty high to have
room to shove the shock in. Any problem using floorjack and jackstands
on a flat surface and getting enough height??
I was notified by ShockWarehouse that mine had arrived so I should be
getting them soon. Installed the rears a few weeks ago.
Larry
LSteiner said:
Raychem,
Larry
Larry, I have access to a lift so install was a non-issue but you can do it like you said above just remove each tire to do the install and compress the shock right before you install it(you have to be quick).
Richard
me too
Got my front ones about 3 wks. ago and installed them on the 6th. Was easier
than the rears actually.
Had the frame up on jackstands and with the suspension hanging down, didn't
need to compress the shocks to install.
Tested on the speed bumps at Home Depot and was pleased with the difference.
Larry
I'm A Bettin'
That '03 on up will work with your '07. I'll put my truck up on that! :-laf ;) Btw, got the fronts in myself, pretty simple. I didn't have a tool big enough to get the rears out so I went to the local tire shop and paid them $20 to install both rears. Pretty dang happy, will give it the tow test later today. :D
