I would like to get some opinions from those of you out there that have slide-ins and are using Bilstein or Rancho shocks. I'm down to my last suspension upgrade (shocks) and I'm still on the fence. Do you think the Bilsteins control sway as good as the Rancho's? I would like to get Bilstein's but I'm afraid that they will not be stiff enough to stop that little side to side sway I get when cruising. It's enough to induce some movement in the steering wheel and if I can't get rid of the sway, I'm going to get rid of the camper, it's a Winnebago 9 1/2' @ 2400 wet. So far I have 265 LR E Michelins (#3400lb capacity each). Factory front sway bar and 1 1/4" Helwig rear bar, Air bags( when the camper is empty I need very little pressure to make it level- about 30psi. ) My stock shocks are worn out big time. After adding the bars and bags the sway is a little better (especially the large sway on turns), but the small sway going straight is still there. I'm convinced now that the shocks are very, very important so I don't want to make a mistake and get Bilsteins and find they are still a little too soft and allow more sway than the Rancho's would have. Truck campers with their high center of gravity need very stiff shocks. Sway control is more important to me than a smooth ride. I had a 10 1/2 foot Coachman years ago that I hauled with a couple of Ford F-250's, they didn't sway like this Dodge does.
Any advice or opinions are greatly appreciated.
