The MAP sensor? I suppose it might be, but I doubt it. As these engines accumulate miles, they will smoke a little, but it should be very much.
Couple of things to check:
1. Check all intercooler boost hoses. Anything between the turbo compressor outlet and the intake horn on the drivers side has the potential to leak. Be sure to inspect and tighten all the clamps. They have a reputation for blowing off.
2. Check wastegate. Make sure it is in the forward position while the engine is off. Might be hanging.
3. If you're running the stock air box, try removing the rubber / plactic tube that goes between the air box and firewall. Over time, they can begin to collapse.
