2nd Gen Non-Engine/Transmission Bleeding ABS Brake System
2nd Gen Non-Engine/Transmission what mods next....?
Engine/Transmission (1998.5 - 2002) Normal Boost Pressures for HO
Is there anything different about bleeding our brakes with rear ABS systems? I'm going to use a vacuum pump to bleed the lines and put DOT 5. 1 back in. Just wondered if the ABS system required any special procedures... :confused:
There is a procedure for just bleeding the ABS unit, but the brake system as a whole is the same. I just did mine a few weeks ago doing the same thing that you do, and no problems. Just a little irritating that I could not get the last 3 tablespoons of old brown fluid out of the rearward half of the reservoir before I started.
