Plowing along, pushing snow off parking lot islands so people can see to turn, etc. Going about 5mph, left wheel hits really big block of ice (let's just call it a concrete wall), wheel hooks, steering wheel spins, screw in steering box drives right out the bottom -- blows it out. Busted. Metal blown apart like china.
No steering, no brakes.
Wrestle one ton truck home with 800lb plow hanging off the front (not easy). I have new appreciation for power steering and power brakes.
No-one carries the steering box for that truck. I'm DOA and snow on the way (darn).
Figure I'll get a jump on the repairs and start taking the old box out. Get lines disconnected, pitman retaining nut off, put on pitman puller. Using an 18 inch long wrench, a 4 foot pry bar, I can barely turn the puller nut. In fact, it started to flatten. How do you get the pitman arm off???? Is there a trick to it? Have to take the tension off it somehow?
Observation: our trucks don't appear to have wheel stops!? You can turn the steering wheel just so far; but nothing actually stops the wheel travel should you hit something.
Should I upgrade some steering components while I have it in pieces? The steering shaft comes to mind. The retaining nut for it was really mushy. Hard to turn but mushy.
