2nd Gen Non-Engine/Transmission Blinking Side Markers
2nd Gen Non-Engine/Transmission dana 80 track-lock on Ebay
Engine/Transmission (1998.5 - 2002) Happy with my truck
I got a diagram for the double relay add on to blink the side markers with the turn signals . Has anyone done this mod and where is a good spot to tie in the lights to the relays on a 97?
Thanks RJ
Most of your work is being done at the rear of the vehicle, so I would find a place back there to mount the relays out of the elements. Unless you have a wiring diagram for your model year, then I would do it either in the cab, or under the hood.
Did you get your wiring diagram from this mod here? I've been thinking about doing this to mine.
Mine is that bronze one in the link. All I did was run a wire from the power of the turn signal up by the headlight to the LED light then grounded it to the body. Simple
