Place I work has power in the parking lot. I work 12 to 13 hr shifts, what do you think about plugging it in when I arrive, and leaving it until I go home.
If it's cold enough to justify it, it's not going to hurt a thing other than the use on your block heater element. You could add a timer to come on 4 hours or so before you need the truck, but I don't think it's an absolute must. Our big trucks at work often get plugged in at the end of the day and left over night without a timer or issue.
Good point, a lot of big trucks are plugged in until needed. From Friday night until Monday morning for many truckers.
Mike.
I talk with the mechanics almost every day, and I don't remember the last time they had to replace an element or had an issue with the heater or related components. I don't know what the power bill is every month with 30+ units plugged in every night this time of year, but it must not be much of an issue compared to one of them not starting for the day. I'm sure the business office would have ordered timers if there was much of a difference.
On a side note, all of the new 2013 Internationals we just received also have Espar heaters on them. Pretty interesting set-up.
Are the Espar units for coolant heat or for cab heat???
Mike.
Never used the block heater for either truck, because I live in So Cal, so I have a simple question, does the heater have a self regulator, like a built in thermostat?
I have a timer on the cord at home, it is heavy duty rated, use it for the above ground pool motor in the summer. Question is, any idea what the rating should be for the timer for the block heater? Can I use one of my light duty Christmas light timers?
The Ram block heaters are 750 watt. I think that will be pushing your light duty timer.
I use this one from Intermatic, but I also have to plug in the company delivery trucks from time to time and wanted a timer that would handle bigger heaters.
http://www.intermatic.com/Products/TimeSwitches/Electromechanical_Switches/24Hour/T100Series.aspx
No matter what is in the dooryard I want a reliable timer. A no-start at -10 below during the work week is not the way I want my day to begin.
Mike.
