Decided to check out my block heater last night - Wanted to plug it in a couple of hours before the daily commute. Took the cover off of the plug and lo and behold - water came out. My guess is the water is condensing due to the 40 degree temperature swings between day and night. The unit worked fine but I'll be drilling a small "vent" hole in the cover so that any trapped moisture doesn't corrode the heater plug. Any body else run into this? PS-It only got down to 39 last night but 11/2 hours of plugged in block heater made a noticeable difference in driveability right "off the blocks"
Jim E. - Newbie to Diesels w/2001-2500Quad-4X4-LB-Bronze Beauty
