everyone who plugs there block heater into an outlet that is protected by a ground fault interrupter has come out after it rained or is raining to find the ground fault has triped. the way i solved this problem is to get a 2 liter soda bottle, cut the top off then make a slit from top to bottom. plug into extension cord, now slide the plug wire into slit so that the plug end and the extension cord end is inside the bottle with the slit side on the bottom. no more triped ground faults no matter how hard it rains. i hope this helps my fellow members out.
95 club cab auto 3. 54 gears pack brake bd torque converter prime loc remote filter horton fan magnaguard rear cover 270hp 620 lbs torque jim jessup tune up
