Do I get a prize for having the correct answer?
Brian
Brian
Originally posted by GDouglas
On turbo gas engines at the dragstrip, we use a bypass valve around the compressor that is controlled by manifold vacuum. Under positive manifold pressure, the valve remains shut and when the throttle is lifted (throttle plate mostly shut) there is then a vacuum in the manifold that opens the bypass valve and therefore connects the discharge of the compressor back to the inlet side to give the excess boost somewhere to go so that the turbo isn't stalled or reversed.
Possibly we could rig some sort of valve controlled by our throttle linkage with our external vacuum pump as a vacuum source to operate such a bypass valve around our turbos.
I am curious to find out what you guys think about this idea.
Originally posted by The patriot
I think you guys are making this way harder than it has to be.
My last car before the truck was a Buick Grand National. The guys that ran these had blowoff valves, but all they were was a header flange welded to the side of the intercooler. On that went a cap, and some long bolts with springs on them. Viola!! Blowoff valve.
Very low tech (sorry not to wow you engineering types![]()
) but it always works, and it's adjustable.
Eric
Originally posted by docdyno
Sounds like a great idea. Early apologies as I too am not very turbo knowledgable. BUT- I work in engineering development and we make engine control systems and control components. It would be very easy to very accurately detect the condition you are describing during deceleration with an inexpensive sensor. We could then build a simple control algorithm (computer formula) to control a servo to open or PWM (pulse width modulate) the valve (Open and close it from our sensor input data) Now before you think I have gone off the deep end and excessively complicated this idea- It really isn't that difficult or expensive to do. The most expensive part is the engineering development- and for interesting "development" projects- The engineering could be real cheap! Anybody have any interest? If so, lets talk about control parameters. I can do the control part- What about the valve hardware?
Originally posted by Mark_Kendrick
We are looking for a valve to be actuated at will not only by pressure.
Originally posted by KatDiesel
I don't have a problem with losing boostOh wait I'm an auto... sorry forgot.
