When I had my Randys transmission installed the installer noted that there was oil leaking from the turbo. I had experienced this before when the drain tube didn't have the correct angles to it. I cleaned it up and proceeded to break in my transmission, every so often checking to see if the turbo was leaking. Normal city and highway driving it does not leak. I went to pick up 2000 lbs of horse feed - checked the turbo after that trip - no leaking. Hauled 13K lbs of alfalfa cubes and found this when i got home. You can see its slinging around the turbo. Oil fill is correct. The oil fill cap sits on top of the oil fill hole loosely and doesn't dance around when idling. The breather is 20K miles old - I removed and inspected, looks fine. I checked the air filter (Mopar) it was dirty, so i replaced it (13K miles on it). The air indicator gauge was all green - in fact I'm wondering if thats workin at all anymore.
108K miles on the vehicle with some heavy towing (reason i have a new transmission)
This video gives a real good explanation on why a turbo leaks
any ideas on what to check? Will an autoengenuity tool help diagnose? Any help much appreciated.
