Blower motor
Engine Vibration After Adding Fuel Plate
IS IT TIME FO A NEW 2001.5 ETH/DEE waiting club
Has anyone had to replace their blower motor? Mine is making an intermittent knocking noise and is getting hot @ the lower bearing. I checked with NAPA- they want $109. 00 for a replacement! Anyone know where I can get one a little more reasonably priced?
Bill Lins Wharton, TX 98 2500 QC SLT,12 (the CORRECT # of)valves,NV4500,3. 54 LSD,Manik grille guard,Psychotty Air,Amsoil everywhere, Reading aluminum utility body and bumper,Optima yellow tops- silencer ring, cat,& muffler all stolen.
Bill,I'm not positive,but I'll bet the same motor is used in a lot of DC rigs,that makes it easy junkyard material. Another option is to pull the motor and get some numbers off it. Granger.com or any electric motor shop can most likely cross it for you. I replaced the blower motor on a John Deere tractor last year,$21 from Granger,JD wanted $180.
Also check bearing supply houses as well as replacing the motor brushes. Usually the bearing is what fails. When you replace them lubricate with some oil and moly grease. I have rebuilt several Mercedes fans using this technique. good luck
Art Hendrickson
Bil, you might try Mopar4less.com, supposed to have good prices. bg
White 99 3500, QC, 3:55, auto. most options except leather, Line-X bed liner, fiberglass running boards Rancho 9000s, bug shield and window vents, black vented 5th wheel tailgate, 100 gal. aux. fuel tank.
