Truck never used to smoke.
Pump died... ... rebuilt pump (230 hp) and new bosch 190 injectors were installed, pump was advanced and 20,000 washers used with the injectors. Lift pump is less than 1 year old.
Truck now smokes..... like all the time blue haze at idle warm or cold. It will also leave a haze trail when slowly accelerating from a stop with no load. Crusing speed, no smoke. The AFC has been backed out pretty much all the way. Truck idles normal, accelerates good (with a mighty puff of black!!), boost is around 28 max and everything else seems fine other than the constant haze. I am using stanadyne fuel conditioner as well..... the haze is the same regardless of if I'm using B5 biodiesel or straight up diesel. No oil is being burned either.
Would something be off with the pump tweeks that were done at the rebuild? Or do I maybe have a bad set of injectors.
This is driving me nuts and I want to deal with it while the parts are still under warranty.
Any ideas?? Thanks.
Any ideas?? Thanks.
