Brake failure
The shuttle valve in the brake system should have switched and blocked off the front system and kept you from losing all the brake fluid, you should still have rear wheel brakes (which wouldn't be much) so if that didn't happen then you have other problems also. I have driven a Dodge truck more than 300,000 miles and never had a leak on the front brakes. bg
