I have a Draw- Tite brake controller on my 98. It is wired up to the factory plug.
When I step on the brake pedal the brake indicator light on the controller does not illuminate and the brakes do not work. If I manually activate the brake lever on the controller it instantly blows the 40-amp fuse on the fuse block under the hood.
I’ve checked all the wiring and cleaned the plug, all the lights and turn signals work fine. Any ideas. Thanks, Jeff
