Mon night the truck tossed the input shaft on the way home from work. When it let loose it took out the clutch(1 week old)the collar in the front of the transmission the bearing retainer for the input shaft and the bottom shaft in the transmission. The now free parts went forward into the clutch which preceded to launch the through the bell housing and it also ate the slave cyl. Quick guess 3k plus in parts alone. Ouch. I will be passing on the Mud bogs this weekend. I just don't think the tow truck would make it to far towing my truck. I will post more later.
Smoker
96 2500 4x4 nv4500 3:54 slt 3"body lift 2. 5" suspension by skyjacker 267/75/16 street tires 36/12. 5/16 swampers for mud silencer ring lost 5" pipe borla KN round style filter JRE stage 4 400hp JRE afc spring kit boost and pyro gauges 16 housing pump timed and 3000rpm limit now 4200
Smoker
