Whew that's one heck of a thread title.
Banks Otto came out in favor of the box!
The banks sputtered alot on the highway with the addition of injectors and in favor of turbo and engine in general ..... out it came!
O. K I am still dialing in this thing and I have made a few passes and now have some data but am still confused.
Keep in mind I also have a Piers PDR hx35 , Van AKEN , DD1's And BHAF.
Best pull with the below settings
Fueling : 50 out of 63
Timing Box : Mild out of Wild
Race Mode ; Street out of DRAG Race
Smoke Control : More perf out of Low/none , Normal ,
Results were pretty hairy as the truck Took off like a racehorse from a glue factory!
RPM ; 3475 ... . WHAAAAT???
Boost ; 44. 9 Guage said it too
EGT ; 986 ... . I dunno 'bout that
RPM Question ... ... Uhhh no overrev codes so what's that about?
EGT Question ... ... Pyro sensor bad????? Seems low
Boost Question ... ... Sorry Piers ... ... . I know its waaay outside it's map!
Now does that seem odd?
As for the VP44 Fueling rate feature reading ... ... Is that a true fuel pressure reading? Sensor is at the inlet of the inj pump and never fell below 12 @WOT but showed Spikes in the 20's
Thanks Kids and adults...
TMTT
<hr>
Truck Bio:
Y2K+1 3500 4X4 Quad Cab 4:10:1 LSD
Somewhat Powerpacked By Bank's (4 inch exhaust,High ram intake,~Minus~wastgate mod to 38 psi,~Minus~ottomind TLC +guages,K&N) ,Blue Chip Premium FMC DTT~93%TC~&~VB~TC Smart controller, Mag-Hytec's Double Deep Trans pan,DD injectors+Van Aken+Autometer Guages. ,Piers Modified PDR HX turbo,Enterprise Engine PerformancePusher pump setup Front End Leveling Kit from Jakit with 255/85R16 BFG http://www.bfgoodrichtires.com/ M/T's Custom Rhino Liner (see Tool Man's truck feature)DeeZee Black Diamond Plate Bed Rails And Tool Box , WAAG Side tubes with kick~outs Mopar Performance accessories-Sill plates-hitch cover-cargo aux lamp'n'Power, Hadley air systems 150 psi comp and air storage. DynaMat Sound deadening applied to entire cab and doors, Check out Tool's Stuff
N. E. T. D. P
TMTT
<hr>
Truck Bio:
N. E. T. D. P
