More tongue weight!!!!!
Steve you need more weight on the hitch, does the trailer sway back and forth at highway speeds also? I had both problems with the first boat (& truck) I owned. The 4WD comments aren't going to help your situation, which is what this site is all about. Check to see if your axle(s) are attached to the frame with u-bolts. Most universal trailers are. If this is the case you can slide them back yourself. Make sure you are on level ground and loosen up the u-bolts. Block the wheels front and rear. After you loosen everything up, pull truck and trailer foreward with a buddy watching. I would go 6-12" back, but you need to watch the length of the brake lines so you are not stretching them. Make sure you mark the frame before you start to move everything. When you get things slid back, measure from the rear end of the frame rails to the "L" channel the axle(s) sits on, on both sides to make sure it tows down the road straight. Tighten everything up, take for a ride and re-measure. If you need more details, e-mail me. Hope this helps!!!
