Bombaholics-1000
Finally Good Steering
ATF Question
Joseph Donnelly
While celebrating Christmas 2000, its time to celebrate 1000 posts also. Since MGM is resurrecting old threads for the occasion, here is an old post for all of you who fear bombaholicism #ad
"My name is Sickly and I wish a REAL bombaholic were around to help me; I am seriously underfueled. "
_____________________________________________
Here is a sad story that demonstrates the addictive power of bombing.
1. A nice new 215 hp Ram was just the thing--good power and mileage. No gas pig feels right, even that gas guzzling 300 hp V10.
2. Hmmm, lets get that TST torque plate and put it on the shelf. That retired guy might be pretty old and die or the little company could go out of business. Good idea just to have it around in case it's not available later.
3. Wonder how hard it would be to put that plate in. Might be worth testing it just a bit.
4. Might as well get that 16 cm2 housing to free up the exhaust. A bit of power and lower egt. Ram feels a bit weak and needs more.
5. Let's try low restriction exhaust and how about that experimental TST plate. Need to get back that "push" that has been missing for a while. Fiddle around a bit with torque plate R&D.
6. Ooopppss. Clutch slipped in 5th. Ohhh, nnooooo. Nothing available. Work with a couple companies to develop clutches. Really stressful not being able to play.
7. Ram feels a bit tired, even sickly, and with the new clutch, a bit more torque plate is just the thing. And work on that exhaust a bit.
8. Not again. Gotta get more clutch. Head porting because even though sick, the egt's are up there.
9. Gotta put in a real torque plate to work with the new clutch; this Ram won't get outta its way. Real sickly. OK, new clutch is holding, just gotta refine the fueling a bit.
10. Wonder if those Diamond B injectors would help the low end. Ya know, the Ram is real sick starting out with those oversize tires in 2nd gear. Ahhh, better now. More like the power and response from the old days. Nice to have that old feeling back.
11. Egt really needs more attention. How about the HX40? Piers came through with just what was needed--a bit bigger and a wastegated 18. 5 so boost won't get too high. Hadda go to 4" exhaust to match the turbo.
12. Those governor springs from Piers are real nice but gotta watch that rpm. "Tapped" the pedal in 3rd. Wow, more power than would be expected from just a turbo. Must be fully flexing those injectors with the added airflow!
13. Oooohhh nnnooooo. Only one good gear. Tires fry in 2nd and clutch fries in 4th and 5th. Like being on ice. Ram feels "OK" in 3rd though. Need a "decent" clutch.
14. Seemed like forever to break in that clutch. OK, now all the gears work. Ram feels almost like it "should. "
15. Wonder about playing with that P7100. It's still stock inside, and that can't be right. Ram does seem to have gotten kinda tired and sickly. Just ho-hum.
16. Guess its time to "touch up" that fueling curve just a bit. Don't think the egt is a problem, well, yet. Nothing has broken, so power level is obviously low--safe to try something to get this Ram up to snuff.
There you are--16 steps to end up with a poor old sickly Ram.
Nice story Joe.
It is sad to watch someone make excuses or reasons for his addiction.
Just accept that you will never be content with alot, you want the most!LOL #ad
Nice story Joe, I just got the #8 plate, now just tell me, how far forward should I really push that thing before I put the cap back on????
96 CC 4X4 2500 SLT AUTO transmission, PrimeLoc, ISSPRO EGT Boost transmission Temp, GUTTED CAT, 150,000+ Miles still goin' strong, Lots of Ham Radio gear, NO IGNITION NOISE!!! Love my diesel!!! TST Fuel plate on the way, BOMBS AWAY!!!
the other thing don't get to close to Joe #ad
He is contagious #ad
this bombing thing is bad. I bomb this thing and it feels good for a day or so and then it's time to bomb again. Thanks Joe for all your help.
Dee
That was a nice story. All true signs of a BOMB alholic. I am hooked. After each time I changed something and the performance improves, it gets old and you want more! I know I do!I started with a 175HP and 200HP later and I still want more! Steve Fyfe
95 4x4 std cab stull grill and bumper inserts,Smitybuilt grille guard chrome rocker panels,Banks Twin ram manifold and exhaust,370 b&d injectors,AFC spring kit Timing advanced,ported head,sachs clutch,18. 5 turbo housing,autometer guagesSnup top shell,two tone,white with blue stripe,33in mud terainson eagle wheels,370HP at the ground
Gene, I'm not making any excuses. It's just that my poor li'l Ram is so underfueled. #ad
What about you? I remember you starting threads on clutches. Could it be that you are a bombaholic? #ad
Something about sledpulling #ad
Surely you wouldn't work your li'l Ram so hard #ad
KB, you better start with that plate in the stock location. Wouldn't want to overfuel that rascal #ad
Save that for when the #4 isn't enough #ad
If you do the #4, 370 injectors, and Superturbo this week, what will you do when it feels sickly again?
Nice story Joe, I guess I better get those 13mm plungers & barrels & that trick s-cam plate on its way down to you before you get the DT's #ad
My name is Chris and I am a Bombaholic.
I just cannot seem to push enough of fuel through the 370 Diamond B injection nozzles, no matter what I do. I found that the fourth clutch I replaced finally solved the slipping problem, but replaced it with the sudden need for the rear end of the truck to want to change lanes during extreme New Jersey highway merging. Tires? I do a good job of melting them too. Am I out of my league with the 5. 9 engine? Maybe I need to shoehorn an 8. 3 between the Ram's framerails. I wonder how much power I can give one of them in such a light application?
Chris Timochko
AUTO WURKS DIESEL R&D TEAM
1997 5sp 4X4, Espar Heater, A. W. D. HX40 turbo, ATS 3pc Manifold, BD 4" Brake, Marine Compression, A. W. D. Custom Tuned Injection Pump, A. W. D. Intercooler, A. W. D. 370B Injection Nozzles, Delivery Valves, Governor & AFC Spring Kit, Psychotty Air, A. W. D. Water Injection, NOS Diesel Kit, A. W. D. 6" Chrome Exhaust System, BD No Smoke Valet Switch, McLeod Dual Disc Clutch, Mag-Hytec Rear Cover, Cummins Chrome Kit, Optima Red Tops, Hadley Bully Horns, Hurst Line Loc, Goodyear Wrangler AT/S 305/70/16s.
Project U96 - 1996 3500 2WD racer. A. W. D. Marine Ultra Low Compression, A. W. D. Teflon-coated Pistons, A. W. D. High Lift Camshaft, Ported and Honed Cylinder Head, Intake and Exhaust manifold; A. W. D. HX40 Turbocharger, ATS 3pc Exhaust Manifold, A. W. D. Water Injection, A. W. D. Custom Fabricated Fuel System, Race Spec A. W. D. /BD P7100 Injection Pump, A. W. D. Custom High Flow Fuel Injection Nozzles, BD Auto transmission and Custom TC, Weld Draglites, Goodyear Eagle Drag Slicks, 5" Single Stack Through The Bed, Mag-Hytec on Rear and Transmission.
It's never better seen than when the head gasket blows and when you have the engine tore down you start thinking of the many things you can do while it's tore down.
Let's see, flow the head, install larger valves, install the marine pistons, high RPM cam, flow the exhaust manifold, send everything to Jet-Hot to get coated, new turbo, do they make a high performance oil cooler, boy, I think the fan is eating up too much hp gotta get rid of that, don't need this grid heater do I?
The searches for better parts goes on and the $300 fix has become $4500 due to you being a bombaholic.
Heard this happened before #ad
Eric
GLTDR
Originally posted by Piers:
OH sure Rich... now ya tell me #ad
heeeheee---when's the new t***** c********* supposed to be released?? (more importantly, when's my wife gonna release the $$$ for the Piers and Darryl retirement fund #ad
gotta score a #ad
fix!!
All right guys, I think it hit. The "BOMB BUG"
has shown its face.
I just finished moving my stock plate foward.
"IT FEELS GOOD" #ad
I think I'll try this awhile before moving on
with the bombing. Need to turn the star wheel
back down tho. #ad
too smokey now.
I can't imagine how a high performance plate
would be like. #ad
I'd be stepping then #ad
Still need them gages now...
I love the new power already, #ad
It may not be
much to others, but it's a whole new truck to me... . #ad
97 3500 dually, ext. cab p/u,5sp,2wd,3:54,245/75R16,
straight pipe,105k mi.
Ron
just wanted to update my new signature. .
I can say ADDICTING #ad
>>>>ye----haw>>>> #ad
straight pipe,105k mi. star wheel loose,plate slid forward, :D I like it :D
Ron
I know I'm not a bombaholic #ad
But it sure does feel good to hear a trucker exclaim "Holy S&%t did you see that cluod of smoke come out of that dodge in front of us?" #ad
Of course I think when we get the twin turbos on it won't be quite as big a cloud.
Ol' WHEEZER
96 2500 4x4 5spd 3. 54 grs, #10 TST plate, AFC spring kit(light spring), 16 cm turbo, CUSTOM 4" exhaust, (turbo to tail), K&N RE-0880 filter, TST guages, 370HP injectors, 3800 rpm governor spring kit,"Accidently" modified fueling curve, Slightly advanced timing(17. 5deg. ) Modified valve lash, Powershot 2000 propane injection system, Mcleod dual disc clutch(street), 315-75R16 Durango AT's, Linex Liner and Rockers,
