I moved my temp probe to the exhaust manifold & found that @ 30psi, I can get to 1400 degrees real fast. The needle wasn't slowing down very fast & it would probably easily go past that.
If you are in the exhaust elbow, adding fuel to get to 30psi, 12cm2 housing, 4" system, no CAT & straight thru muffler, unknown timing, 90 degrees ambient, pre-turbo temp = temp reading + ( 30 x 20 ). In my case, my exhaust elbow temp was 900 degrees. Pre turbo, that's 1500 degrees!!
Money Sink - 96, 5 speed, Injectors, 280/685 & AFC housing slid.
4" CAT back & CATless, 4" chrome turn down straight out back.
ISSPRO Pillar, Delvac 1 & Amsiol, K&N, Monicas silencer ring removed, Exhaust brake, Mag-Hytec, 3:54, 235s.
HX35s days are numbered, HX40-16 is here.
Un-Bombed = Boring
Un-Bombed = Boring
