Sorry, not sure what you mean "cover on the gates" and "pucks". I'm thinking there's something "cover" that can be removed to inspect the "pucks" (sealing mechanism" that closes off vent/gate. As for psi of system, new silicon hoses installed and inspected inter-cooler while tabbing dowel (had radiator out BC no big wrench to get fan off of pulley and was able to visual both sides of IC).
I checked all hoses and not one has budged = all were installed with no kinks or otherwise faulty installation. Old hoses were still good just 10 years + 180k old = boost was low prior to tabbing and new boots.
I'm wondering if there's a dirty electronic sensor, MAP, IAT, or ? that would cause this?
Back when first installed I had a 0 - 30 gage that wasn't reading anything, guess I blew the gage first time I romped on it, anyway performance seem excellent but it was suggested to clamp WG hose to see if there was any difference. Which I did for a mild run and since no diff I took clamp off hose. I guess I could try that again, but if there's an internal leak in the WG this wouldn't prove anything - Yes?
