Boost and Pyro Fittings
first ever duramax twin turbo setup
Cummins almost dies when returning to idle?
I want to use my old pyro guage and boost gauge that I had on my PSD. The pyro had the band clamp holding the thermocouple in place instead of the 1/8" NPT and compression fittings. So I need new ones. I also need the boost gauge fittings and line. Can someone recommend a sponsor that could hook me up quick??
Thanks
How big is the boost line and what size NPT port are you trying to install it into? If it were me, I'd order a new tube fitting from here. Unless they have a distributor close to you, then you can just go pick up the fitting.
For example, a 1/16 OD tube fitting with a 1/16 MNPT end is part number B-100-1-1BT (brass). $3. 20.
Or, I've ordered a boost tube kit from Isspro in the past that included the aforementioned fitting.
Geno's doesn't seem real friendly to special orders... do they carry the boost tubing and fittings normally?
-Ryan
-Ryan
Thanks guys. I didnt realize it but JEGS carries the fittings I needed. Got them the next day and installed them the same day. Now its on to my other problems before I fire this thing up.
