boost and pyro gauge where to get them???
Who has the best deal on e-brakes?
Neat little toy
Here's a couple of links. There's alot of places to get gauges, etc. , you have to decide on what you want to put in your truck.
http://www.performancediesel. bigstep.com/category.html?UCIDs=578092%7C579181
http://www.tstproducts.com/
http://www.genosgarage.com/
http://store.summitracing.com/main.asp?ssid=Q1TPF2P6TLI8RE2VQBS4XSLMPN&d=&dn=
http://www.bullydog.com/
http://www.dieseldynamics.com/
http://www.westach.com/products.htm#AUTOMOTIVE
That should keep you busy for a while #ad
Scott W.
White 2001. 5 3500 ETH/DEE 4X4 Quad cab SLT,tow package and camper prep,Husky liners front and rear,DiPricol pyro,boost and oil temp gauges,Edge EZ,Psychotty air,Bully Dog stage III injectors,ATS 3 piece manifold,HX40 turbo,4" BD exhaust,4" BD E-brake,McLeod clutch,Mallory 4150 lift pump,Mag-Hytec rear,Mopar tonneau,Lund bug shield,PM tractor utility back up lights,Penda bed mat and blow by bottle is bye bye !!! I love the smell of diesel in the morning, it reminds me of... . VICTORY !!!
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089608" TARGET=_blank><font color=red>My Truck</font></A>
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089604" TARGET=_blank><font color=red>THE SAINTS</font></A>
Long time member, first time post. Thanks for all the info in the past, folks.
I *really* like the service I got from Jannetty Racing Enterprises when I ordered my guages. Sent me everything right, first time and quickly to boot. (Thanks, Ted)
I ordered the triple full pillar pod, Autometer Ultra Lite Boost and AutoMeter UL EGT. The boost is 0-50psi, btw, only source I know of for them. Plan to order a fuel pressure guage for the third.
I mounted my boost fitting in the 3/4" pipe hole in the intake using two adaptors to neck it down to fit the supplied fitting. (Bought the adaptors at Home Depot)
Drilled and taped the exaust manifold with tap and bit from Sears, tested on scrap aluminum to be sure of proper fit. When tapping, I used grease to catch filings and cleaned up with a magnet, afterwards. The more you run the pipe style tap in, the further the fitting will screw in. You want the fitting to stop flush with the inside surface so it was stop and check as I created the threads so as not to run the fitting in too deep when tighted in. I measured the inside diameter (eyeballed) and made a red mark on the probe so that when slid down in place, the probe would stop mid-way in the exauste stream. I used anti-sieze on the treads of the fitting going into the manifold on the EGT probe. (teflon tape on the threads of the boost fittings)
I painted the pod with SEM Bumper Coater #39163 Smoke M (medium) spray paint. I matched the Agate interior with a color sheet from an automotive paint supplier. Matches great, though it's a full pod and not right against existing as would be a half pod. (I slightly heated the can with a torch while shaking to get it to flow good when spraying, big difference in laying down the paint, looks like factory color of the plastic, not sprayed on. No need for a cup gun and mix when a spray can works great. (Warning: can says not to heat up or store above 120F)
I wired up at the fuse box with wire under the fuse. Pyro box 12volt from radio fuse, guage lights from illum fuse to work with dimmer. I daisy chained the guage lights from one guage to the other. The wires under the fuses (shoved in with fuse)are on the fused side of the sockets. Checked which side was fused with voltmeter with fuse out. Outside from center is fused side. Grounds go to a screw in the firewall. Small box for pyrometer is under the dash, wires came through firewall through existing hole that hood latch cable comes through, left of clutch.
Pics of Truck,Guages/Pod,Guages at night,Boost fitting installed, EGT fitting installed, fuse box wireing, guage wireing, paint can sitting on my other truck (1ton chevy M1008) at:
Website
Soon will have lots of pics from Daytona Speedweek 2001. I was down there with Team Mansion Motorsports #85, Carl Long. Looking For sponsors, BTW! Nascar Dyno Vids with awesome sound, Lots of Truck Stuff there too!
thanks you all them link's
AYSCII. do you happen to have the order# for your gauges i like the look. gonna have to find a pillar mount somewhere else i have a 93 . . thank you in advance
The BD website shows a pillar mount for our earlier model rigs. Just look up the price pages for the accessories under Dodge.
J-eh
Jason Hoffman
Lil' Mack - 89 D250LE 5 Spd 3. 54 LSD Reg Cab. K&N,"tweaked pump", BD Injectors, Banks Pyro/Boost, 3. 5" Exst tail section straight. E&M Custom seats. Bosch H4, PIAA 80W/80W HdLites. 100W Drv,55W Fogs.
237,500 miles (380,000 Kms) 7850 Hrs. Cummins Power Booster member.
The Original Turbo Diesel
Lil' Mack Pics/March 2001
[This message has been edited by Lil' Dog (edited 03-16-2001). ]
Cummins kid try Diesel Injection Service out of Texas. I just bought my Autometer Ultra lights from them great Price #ad
Nice people to work with ! They also have the 0-60 boost gauge. They had my 2 gauge pillar there for a 96, they might have something there for you.
The order numbers from Jannetty Racing Enterprises are:
ATM-4304SP (50 PSI BOOST Autometer Ultralite)
ATM-4365 (EGT Autometer Ultralite)
Both 2 1/16" diam.
ATM-5244 Comp. EGT Probe kit 1/8" diam.
ATM-17203 98-01 Dodge 3 hole full pillar
mount, no speaker
The folks on the phone walked me right through what I needed, no problem.
Steve Ayscue -- email address removed --
  • 98 2500HD Cummins ISB,LB Quad,White, A. R. E. Topper,Line-X, Rancho 9000's, BFG AT KO's 295/75/16, Cobra 75WX, USCGAUX
    DDII's Waiting to go in
    Autometer Ultralite's (Boost/EGT) soon fuel pressure
  • 86' Chevy 1ton M1008 w/6. 2 Dsl
    ready to fix up
Yep, it's an A. R. E. MX series. The A. R. E. website is: http://www/4are.com
I ordered the roof rack on the outside and replaced 4 of the screws with longer ones so they stick through to inside the truck. I mounted a board across between each pair, side to side and mounted Berkley rod racks to the board. Here's a picture of the front section of my rod racks:
    ready to fix up
AYSCII, on a different note... . is that an A. R. E. cap on your Ram?
01 2500 Sport, QC, LWB, Auto, 4. 10, 4x4, Camper Pkg, Tow Pkg, Geno's muffler eliminator pipe, rest is stock for now
Dumb question:
I'm going to install a boost gauge, and I want as much information as I can get before I order parts and such. Each boost gauge I've found has been listed under the "mechanical gauge" section of the manufacturer's catalogs and web sites. This means that I have to run a pressurized hose into the back of the gauge, right? #ad
If so, has anyone had problems doing this with a pillar-style gauge mount? Does anyone make an electrical air pressure guage so I can leave the sender under the hood?
--J
John Miller
'01 2500 Quad Cab, ETC-DDX, SLT, Long Bed 4X4, Tow, Travel, 3. 54, Camper spl, Forest Green, Line-X
bed liner, silencer ring removed
AYSCII THANK YOU FOR ALL THAT IM PRETTY SURE IM GOING TO GO WITH Jannetty Racing Enterprises CALLED THEM UP WERE VERY NICE TOLD ME EVERYTHING I NEEDED TO KNOW HOWEVER IF ANYONE KNOW'S OF SOMEWHERE NOONE MENTIONED PLEASE LET ME KNOW... THANK YOU ALL FOR YOUR HELP . JASON
1993 LE 250 4X4 AUTO 95,000
MILES. BED RACKS. ALL STOCK ... FOR NOW... .
JJMiller:
Take a look at the SPA electronic EGT and Boost combo gauge. The boost transducer mounts directly in the port, or in my case in a high pressure street el that is in the port. The gauge is digital with a programable memory. It will remember and display your highest EGT and boost readings since last reset. You can also program limits in both boost and EGT, when you hit those limits a warning light in the gauge will light. You can even wire in an external light or buzzer. Gene
'96' 3500, 5-speed, 3. 54 LSD, Ext. Cab, 180,000 plus miles, relay controlled back-up alarm and rear facing halogen tractor flood lights, K&N air filter, TST #11 plate . 010" forward of stock, AFC spring kit, lost cat, SPA digital EGT and boost gauge,20 yr. old marine air horns, bed liner, 5" monster exhaust tip, Geno's manual trans. filter, brite box.
I second the SPA gauge. Check the link in my sig for a nice picture.
John D. Rathert Jr.
01 2500 Forrest Green Sport SLT+ QC LWB 4x4 Auto 3. 54 rear end with all options avail. DC Nerf Bars, DC Grill Guard, DC mud flaps, Line-X bed liner, Leer 160XL Topper, Power Edge, EZ Edge, SPA Boost/EGT Gauge on pillar mount, DTT's tc/vb combo, 275 RV injectors, DD 4" Exhaust and a KN RE0880 where the air box use to be. New turbo (HX40), SS fuel lines and bigger injectors in planning stages... . See My Truck, Dads truck: 98. 5 3500 SLT QC LWB 4x4, Brother Truck: 92 W250 SLT CC LWB 4x4 (Dads old truck) Winter fun - 2000 Skidoo Summit 700
I am my own warranty station. ZOOM ZOOM
VDO !
Thanks for the eguages.com info.
I just couldn't warm up to the Autometer/Isspro/Spa offerings at all the diesel shops.
VDO is what I'm used to and what I want Simple and Clean. :D
Now I'll go work on my Phord for to sell it--for that will fund my injectors and boxomatic.
