both not just the elbow??
Ok,
so I would need a box that tells my ECM that I am not getting the boost that I am and an elbow that limits the wastegate pressure so it doesn't dump the increased boost... ... ... ..... correct?
And hopefully the box is one that adds fuel to assist in the increase in air from the boost... ... ... . is that right?
What would happen if you added the "elbow" that decreases the pressure to the wastegate... ... ... . which will allow more boost to build without adding more fuel to the system????
Will it lean out the mixture?
Less power?
Chance of burning a piston like in a gasser??
Thanks for the help guys,
Deano
