Engine/Transmission (1994 - 1998) boost gauge/egt
where should i run the line for my new boost gauge to ?putting a triple gauge pod in my 95. and opinions on thew egt gauge sender also
There is a little plug in the intake manifold that you can take out and plumb it in there. That is what the instructions on my isspro gauges said to do and it was quite easy.
I don't know about Matt's '94, but my '95 is like EKlem says. That's where I ran mine.
As far as the pyro goes, you'll have to drill and tap the exhaust manifold.
Scott
There is a plug in the intake manifold even with the cap between the 4th and 5th delivery valves. It's 1/8" NPT so all you have to do is remove it and install a barbed fitting.
Directly below the intake heater right? Thats where my AFC line goes into. Yup 1/8'' NPT is what it is too, but mine isn't plugged. Apparently this is a 94' only deal, I also have a metal AFC line what do you all have? Where does your AFC feed come from???
my 96 had a plug a couple inches infront of the fitting that feeds the afc that i screwed into
I replaced a bolt on my intake manifold with a 1/8 NPT fitting and connected there. The bolt is about 2/3 of the way towards the back just behind the intercooler piping. Easy to get to. Only thing you need to be careful of is that some of the intake bolts don't go into the inside of the intake but instead of straight through. I'd send a picture but won't be home for a week or so. I have an exhaust manifold which was tapped for the pyro so that install was easy also.
NO. In Front of the grid heater on the side of the manifold. I'll take a picture sometime in the morning and post it. Look at the side of the manifold thru the gap between #4 and #5 delivery valves.
I have the same metal AFC line coming from the intake on my '95, but I had an extra plug on the manifold to hook my boost line to. Check the pic and you can see the boost fitting in the front and the AFC line towards the back. Yes, I know I need to slide a little vacuum line or loom over my line :p
