Boost gauge on First gen
Good Cummins Mechanic? Florida
Need info quick
No drilling. There's an unused 1/8" NPT port just below the intake horn on the manifold. Just remove the plug and your boost gauge fitting should screw right in. ;)
OOOHH!! Sexy BLUE I/C hose... ... . I like it!! :D
Sorry, got side tracked by the pretty color. Where he said is the hot ticket to tap in! :)
There's also a "boost bolt" that you can get - replaces one of the intake manifold cover inner bolts. Has a quick release fitting so you don't have to worry about over tightening the compression fitting on the tubing to the gauge.
