I just recieved my isspro boost and pyrometer gauges from Geno's garage. The boost gauge came with a tapped bolt which the directions say to remove one of the intake manifold bolts and replace it with this tapped bolt for the plastic line. I have an 05 325/610 and there is a tapped hole in the front end of the intake manifold that has nothing in it. The tapped bolt for the boost gauge fits in this hole perfectly. Does anyone with a 325/610 know if you can use this hole for that purpose. If so, do you need to remove the intake manifold to punch the hole the rest of the way out or cut a hole in the manifold gasket? I'm assuming the hole would be sealed or you would have an intake leak. Thanks.
