Alaskdave, your tubing most likely has a kink in it. That type of small stiff tubing is very susceptible to it. The way I've found to prevent it is to push the small tube though another 1/4" id tube. This will also prevent it from getting cut on any sharp edges.
Dave F, I have found that mechanical pressure gauges will get damaged during a hard freeze, even if there is just air in them. They usually read high and don't return to zero, but will also sometimes not work at all, no leakage. Of the at least 50 pressure gauges on my orchard irrigation system I will lose maybe five every winter. Sometimes I've been able to remove the glass and pull the needle off and reposition it at zero, but most of the time I just replace the gauge. They are very delicate inside, you would almost have to be a watch maker to repair one. My mechanical fuel pressure gauge bit it last winter on a below zero night when I forgot to plug in, started reading 5 psi high. I have found that plugging in the block heater will keep the cab above freezing even when the temp drops below zero. Replacing a gauge is probably cheaper than paying for power for most folks, although a combo gauge can get pricey, maybe it isn't the best way to go for this reason.
