2nd Gen Non-Engine/Transmission boost gauges
Engine/Transmission (1998.5 - 2002) Clutch Pedal Adjustment?
Does anyone have any ideas on how to use one boost gauge to read two different pressure sources? i. e. engine boost and exhaust brake pressure Thanks.
One of those small manual valves from home depot and some compression fittings, outta do it. If you need an in-cab switch, hook a push-pull cable up to the manual valve.
An electric 3-way solenoid would do it. I use ASCO brand at work, and I know you can get 12 volt coils. A toggle switch in the cab would control it.
Correct me if Im wrong, but isnt turbo boost while droping down a grade usually somewhere around zero, and the same for engine brake pressure while the engine is under a load? ;)
