I am looking for a boost leak that doesn't squeal all the Time . When truck is cold I can get it to squeal and goes away when I lift, after it warms up it may not do it. I have psi tested to 20# which it will not hold. I can hear air under valve cover and when I remove oil cap It is louder. I soap all boot connections. Do not hear air any other places. Should the psi hold when checking. My mechanic told me that you can not psi test because the valves will be open and blow right out exhaust. Any suggestions?
