I finally added the gauges yesturday--Autometer 0-35 boost, 0-1600 pyro, trans temp. Now my question is what type of boost numbers should be normal for my application?
Boost is taken from intake air horn drill & tapped on back side, EZ box on 3rd setting (factory)w/Boost elbo, stock injectors, stock TC, 4. 10 gears, Ray's Banjo-bolts--all 5.
So far I have seen a Max of 24 psi empty WOT up hills and even on level ground, I thought it would be more. EGT's are 1000 max.
I also have a 4 psi pressure switch in Injection Pump banjo-bolt connected to a light mounted in A-piller--light will flicker, when WOT, but will go out. See signature for truck bio.
Max
Max
